thundrous
Junior Member level 3
Hi, in the following video, you can see a signal modulation. we are sweeping a frequency range from 300kHz to 6GHz by VNA meanwhile applying 1V and 5kHz signal from signal generator to the bias tee built in the VNA.
Unfortunately, if I increase the 5kHz signal from the signal generator the bias tee filter the signal. How can I do this signal modulation? is there any specific bias tee, diplexer, or directional coupler for doing this job?
I am new in RF measurement and any suggestions are appreciated.
I need a passive device or a method in which I can apply these two signals in a signal modulation way.
Thanks.
Thanks.
