surkris
I have a 1KHz sine wave synchronized to a 1KHz TTL square wave. I need to control the peak-to-peak voltage-level of the 1KHz sinewave. I require two gain settings 1.5 and 0.5. Would it be possible for me to use an OPAMP for this function? The problem might be that at 1KHz and at the required gain settings , there would be some amount of phase shift, however small. I need to maintain the original phase with an error of about 1 degree or so.
Can anyone suggest a suitable approach?
