Need for Switching mode Power Supply from 24V to 5V
dkace
Full Member level 6
Full Member level 6
Greece
lm2574 power supply
I need a device as above that can drive a 500mA load . Can someone suggest something?
LM2574 and similar parts from national semiconductor do the task,but they are non-isolated,you can also buy DC/DC converters at reaonable prices from TI and minmax(www.minmax.com.tw) they have 24 to 5 at 0.5A
I have good experience with MIC4680 (Vin 34V max, Iout 1A, SOP8)
Look on **broken link removed**
JURS
We have positive result with NATIONAl LM3478 + external MOSFET
with this IC you can make many others topologies.
In our case we develop -60V -> -12 V with common +60 rail.
Tha Maxim MAX724 is nice to use - internal switch and just the usual few passives and small inductor. Output voltage is adjustable, input can be up to 40V, 100KHz oscillator, 5-pin TO220 package.
I like 'em!
FoxyRick.
LM2574 is easy to use and gives you 5V@0.5A
Are there any products with 230VAC in and 5VDC@1A out?
See STM Viper or Power Integration TOPSwitch families
Linear has a free program (SwCADIII)
you can insert your inputs (Vin, Vout, I...)
and the program draw a schematic
h**p://www.linear.com/company/software.jsp
use lm2596 National is veri good
Hello
You might want to examine TI's sample list for plug-in power solutions...
Regards
Take a look at maxim-ic homepage. E.g., MAX831 is a DC-DC step down converter, 5V 0.5A output, and high efficiency.
MC34063 is very cheap and easy to design, it can be configured as step-up or step-down mode. But it's working freq is low, that means a big inductor is needed.
Mike
www.ezpcb.com
From TI TL497 very good ic
