Quote microwave: With single supply, you need to use an IC to generate negative voltage for the negative rail for the OpAmp.
I don't think so. A simple voltage divider can do.
I don't want negative voltage. I want to amplify a signal that goes to a micro controller ADC with 0-5V. So I want a rail to rail op-amp that use single supply so that I can bais it somewhere at 2.5V and still get 0 to 5V using a battery. I have found a couple of op-amps, which are: TLC272, LT1466, LM324N, TLV2771, LM6144. What could be the best choice?
