Need DDS module with 2 outputs, 90 deg phase shift
banner
Member level 1
iran
DDS module
i need a DDS with two out put with 90 deg phase shift?
thanks,
Re: DDS module
You could use the AD9958, although it might be overkill for your application. Then again, it might be a perfect fit for your application, since you did not specify what that is.
Reactions: neazoi
    neazoi
Re: DDS module
does AD9858 have two output with 90 deg phase shift at the same time?
i want to generate two 500MHz with 90 deg phase shift?
Reactions: neazoi
    neazoi
Re: DDS module
It's got 2 separate DDS cores running on the same clock source. You would have to put both channels at the same frequency and program the phase shift register of one of the channels to 90 degrees difference. The DDS has only 2 DACs...
Added after 3 minutes:
After rereading your reply I noticed you said "AD9858", whereas I was talking about the AD9958. I assume your "AD9858" was a typo?
Reactions: neazoi
    neazoi
