-Need Cristal Emulator or Generator via Software or Hardware
HasanZara
Newbie level 3
Newbie level 3
:oops:
hi ppl. i need for a projeckt adjustable crystal (OSC) for microcontroller or another one. like 4mhz to 20 mhz (3.5,7.0,or 14 etc)
how i do its ? can microcontroller its ?
Best REgards
Hasan Zara Basan
i dont need like this 4mhz,8mhz,14mhz via jumper etc...
i want direkt adjust crystal
Hi
One way it to use a pll mutiplier.
Second way take a high clock from osc and divide it with logic.
Best regards. 8)
Take a PIC Prozessor ( 16F870) or an other whis an Analog imput.
Put an Potentiometer on the Analoginput, an write a little Software that read the analogport.
Than make an Softwaredivider
Or take an VCO 74628
That work from 1Hz to 20Mhz
Mike
Look Maxim-Dallas EconOscillators/Dividers:
h**p://para.maxim-ic.com/compare.asp?Fam=EconOsc&Tree=Timers&HP=Timers.cfm
Thank you to all
:) wonderfull.
But i need more if have like schema etc..
i am continue to learn about its..
Best Regards
