Need Code for 0 to 1 Transition
carrot
Full Member level 3
Full Member level 3
Bangalore, India
Hi ,
When input is transitioning from 0 to 1, output should be asserted for 1 cycle (in same cycle) with synchronous clock.
how will the verilog code look like?
Thanks,
Carrot
always@(posedge clk 0r negedge rst)
begin
if(~rst)
a_f <= 1'b0;
else
a_f <= input_a;
end
assign zero_to_one_transition = !a_f && input_a;
begin
if(~rst)
output_f <= 1'b0;
else if(zero_to_one_transition)
output_f <= 1'b1;
else
output_f <= 1'b0;
end
endmodule
Hope this helps
Reactions: carrot
    carrot
can u clearly explain?? i cant understand your requirement??
Reactions: carrot
    carrot
Something like this:
Code Verilog - [expand]
8
reg your_signal;
reg delayed_your_signal;
reg edge_detect;
always@(posedge clk) begin
    delayed_your_signal <= your_signal;
    edge_detect         <= your_signal & ~delayed_you_signal;
end
The "your_signal" can be a module input instead of a register, etc. But you get the idea.
Oh wait, I read it wrong. You say "in same cycle". Then you want a combinational circuit on the output. In which case sakthikumaran87 already gave you the answer. The "zero_to_one_transition" signal is what you want then. Anyways, if neither of the offered options is what you're looking for, please clarify the requirements.
Also see this thread on the same topic.
Reactions: carrot
    carrot
