suria3
Full Member level 5
common mode logic
Dear People,
Currently i'm doing research on CML Design. From what i have found so far, there were no fixed common mode voltage or signal swing for both CML driver and receiver. From the collected datasheets from many companies, what can I see is there are some range but not a fixed one. For example :-
1) Maxim
- CML Driver Differential Output Swing ( 640mVpp - 1000mVpp)
- CML Receiver Differential Input Swing (400mVpp - 1200mVpp)
2) Other companies
- CML Driver Differential Output Swing (400mVpp - 1300Vpp)
- CML Receiver Differentilal Input Swing (400mVpp - 1600mVpp)
So, can anyone clarify for me what is the actual swing range needed by both the CML Driver and Receiver and the DC Common mode as well like LVDS have 1.2V CM with 800mVpp differentially.
Is there any standard i need to follow on.
Now let say, my typical design is 800mVpp differentially, is that mean that for any temp & process variation , my signal swing must be exactly 800mVpp or it can change within the range??
Thanks in advance,
Suria3
Dear People,
1) Maxim
2) Other companies
Thanks in advance,
Suria3
