To add to it; does anyone have experience in designing a supply from a rechargeable battery and a solar panel. The supply should maintain a constant voltage and also charge the battery,
Best battery chargers are switching type, more efficiency and voltage regulation,
and for solar panel charger are switching type too.
Solar panels needs ones with large voltage variation , low light = low voltage , high lighting = high voltage .
See atteched PDF
