Need altium short cut ??
kabaleevisu
Advanced Member level 2
Chennai,India
Hi everyone,
right now i am learning Altium tool. i need some short cut for following commands
how to add board outline ?
Routing short cut ??
add copper short cut ??
multiple trace routing short cut ??
add via ??
Find the components ?
Zoom in and Zoom out ??
how to add board outline ? D-> S
Routing short cut ?? P->T
add copper short cut ?? P->F
multiple trace routing short cut ?? P->M
add via ?? P->V
Find the components ? E->J->C
Zoom in and Zoom out ?? CTRL+Scroll
Regards
skr
Hi
could you please help for creating footprint in altium ? is there any video is there for creation footprint
how to delete the sheet..please reply any one
how to set the gerber in altium please reply any one
how to import the routing and placement from one board to another board
delete sheet -> right click on sheet to be removed and hit delete/remove from project
set the gerber -> in output job file, gerber output option need to be configured
to import the routing and placement from other board -> use import option in altium
Regards
skr
hi sankurathri,
i import the dxf for my design. Dxf came out of PCB how to set the origin for dxf or is i need to move board shape or is i need to move DXF
You can redefine the board shape based on our DXF file. Select the required board outlines in the DXF file, then select "Design » Board Shape » Define from selected objects" . It will shape and place the board onto your DXf file.
To change the routing layers, use the + and - keys in the numeric keypad while routing.
is i need to draw board outline over the dxf ??
https://www.edaboard.com/threads/312553/
both are same thread only reply for that also
Select the board enclosing lines in the DXF file and run " Define from selected objects".
Refer **broken link removed** for details
Tip for Altium,
Almost everything is in the menus, and almost everything has a keyboard shortcut that can be discovered from the menus, for example (AD14) to select all the connected copper on a single layer belonging to a given net, select the net then Edit (E), select connected copper (S), single layer (S), the keyboard shortcut is E-S-S.
The menus really do make the keyboard shortcuts easy to discover, and the shortcuts are very much worth learning (they make layout **MUCH** faster).
Regards, Dan.
Here i attached my board file.i could not process your procedure.please help and look at the board better provide your mail id for further learning if you are interest....
  • layout.rar
In the DXF file, your board outline lies in layer mechanical 1.
So select mechanical1 and then Edit->Select->All on layer (Shortcut S for select menu) which selects everything on mechanical1 and then you can run command define boardshape from selected objects.
You can also do like this. Select mech1 and press Shift+S (Which masks all layers except mech1). Then select the board outlines (In your case you can select all on mech1 by Ctrl+A since you don't have anything else on mech1 outside the board outlines).Then define board shape.
You can mail me at techgreed@outlook.com . Iam also new to this world but can help you in things i know :)
Here is the attached file.
  • PCB1_1.zip
is i need to assign the board outline in one layer (Mechanical only right) ??
How to change the layer type after imported DXF ?? i want to select the all the line and curve
is it possible to add curve in edge of board outline ??
The board outlines has to be on the same layer. Its not a must that it has to be on a mechanical layer(Normally its mechanical layer always).
To change the layer of any object, double click it, which opens a sub-window. There you will find the option to change the layer.
If you have multiple lines/objects for which layer has to be changed, its better to use PCBInspector. Select the lines you want to change and then press key F11. This opens PCBInspector window which shows the properties of the selected objects. Then you can make the changes.
Hi kabaleevisu,
If you want learn altium, please do a visit to Fedevel blog... There you will get all the videos related to your questions.
https://www.fedevel.com/welldoneblo...with-altium-designer-all-in-17-minutes-video/
To know about every individual options of altium... Please visit the following link...
https://altiumvideos.live.altium.com/
You can get the tips & short cuts from altium itself. While you are in a comment press F1 to pop-up the available options & short cuts...
(Instal "internet download manager" & go to the video link & you can download the video at the same time by clicking the popup down loader.)
Regards
Udhay
Hi udhay,
thanks for your help.let me know how to change title block in altium schematic ?? i saw some video through that only i am learning but small things i could not clear it will take time
i believe you are talking about "Document parameter". You can access from schematic sheet "Design>Document options> Document Parameters" (Short cut is "O>T")& fill the required fields. You can insert your logo by using "Place> Drawing Tolls> Graphic".
Regards
