udhay_cit
Full Member level 6
Is there any way to select only the via in the PCB layout by using query builder?
When i use the polygon pour option in altium designer, i need to give direct connection option for ground stitching via's & at the same time i need to give thermal relief connection for through hole pads. Now i am using "InNet('GND') And OnLayer('Multi-Layer')" command & its selecting both via's & TH pads. The direct connected TH pads makes very difficult to rework the PCBs...
Regards
Udhay
Regards
Udhay
