Buriedcode
Full Member level 6
I've been reading up on error correction for a wireless design of mine and I'm a bit stuck at the moment. The design already uses 'hamming codes' implemented in hardware (schematic entry) using the 12,8 code, modified to a 13,8 code for double error detection. Seeing as I'm sending a 16-bit word, I simply split it up into two bytes, so each byte has its own error correcting capability (total of 2 errors, 1 in each byte corrected, 2 in each detected). So I'm sending 26 bits in total, but I have room for 32.
Now, this is quite simple to do, and works beautifully with the MACH4's I've got. I was originally going to use convolutional coding, but decoding requires extensive hardware/software, even when using the simplest algorithms. Also latency is a problem because I'm after <2ms from transmit to recieve.
I'm really just asking if anyone has heard of any less-known codes, block, systematic, cyclic, that can correct multiple errors in a 16-bit word with a maximum overhead of 16 bits. The encoding/decoding has to be simple (using 64 macrocell CPLD's), preferably 'on the fly'. A special 'reed-solomon' code looks OK (32,16,5) but the decoding is a bit of a nightmare.
Any links, advice, code, schematics or ideas are welcome. Its just a hobby of mine that I've become a bit obsessed with :?
Ps. I have also implented a (8,4) hamming code 4 times for the 16 bits, giving a pseudo (32,16) hamming code, but its messy.
Thankyou.
BuriedCode.
Thankyou.
BuriedCode.
