Need advice :: layer stack with symmetric voltage supply
isco
Newbie level 2
Newbie level 2
Hello,
I’m an interested reader for a long time, but this is my first entry. Sorry for my rusty English, but I will do my best.
I have the following question:
I have to design a pcb with 6 layers. The outer layers are reserved for signal routing. The inner layers are for the symmetrical power supply of the board. That mean’s 2 inner layers for GND and the last 2 layers are for ±15V.
Layer-stack:
Signal
GND
+15V
-15V
GND
Signal
Remark: From the viewpoint of the signal-layers, there is no need for impedance controlled layer-stack.
What will be the best layer stack for this task. After which criterions do you select?
Thanks,
isco
Are there any proposals?
Perhaps yesterday I did not make myself totally clear.
What i want to know: What kind/width of Prepregs are recommended between the layers? After which criterions should i select?
Layer-stack:
Signal
GND
+15V
-15V
GND
Signal
thanks again...
Stack is ok.Regarding thickness you can check with ur fabricator what is available with him.
Copper thickness is based on your current rating of the planes...
