Need AD9835 for Proteus isis
Eng.Fahd
Junior Member level 3
I need to simulate my project in proteus isis , I didn't find AD9835 in libraries ... I want this device library .... Thanks
I need to simulate it ... If nobody has this lib, help me with designing it , I have some information about creating new digital devices,, but not analog ... can someone help me .
I had a similar problem with the AD9850, my solution was to add shift registers with seven segment displays attached to them so I could see what was being programed in to the chip. Not a ideal solution but good enough for debugging purposes. The watch window in Proteus could also be used if the data to be programed into the chip is held in a register first.
Thanks alot pjmelect , Can you give me the Proteus file of your idea because I didn't understand it .
Thanks, I got it and it works , nice idea.
Hello
please can you send to me the proteus file because i have the same problem
