[SOLVED] Need a sample c- code for displaying register data on lcd (16x2) .
abv
Newbie level 5
Newbie level 5
I'm new to analog part of 16f877a .Also I didn't know how to print directly from register (ADRESL/H) because i always use pointer to display on my lcd.
I'm using MPLab with htc compiler.Please help me to get a sample C-code for displaying from register. :|
//configuration part
 TRISA=0x01; ADCON1=0xc0;        //port A.0 ADC input
//adc read function
unsigned int read_adc()
unsigned int temp;
  ADCON0=0x81;    //read from ADC channel 1
  __delay_ms(1);    //setting time
  ADGO=1;    while(ADGO);   // wait until ADC conversion complete
  temp=(ADRESH<<8|ADRESL);  // combine 10 bit result
return temp;
//display function
void lcd_number_display(unsigned int adc)
 unsigned char a[5]={0,0,0,0,0},cnt=0;
if(adc==0) { cnt=1; }
    while(adc)
		a[cnt++]=(adc%10);
		adc=(adc/10);
     while(cnt--)
       lcd_data((a[cnt]+'0'));    //your single character display  LCD function    [ +'0' means  add ascii value for display ]
Reactions: abv
    abv
//adc read function
unsigned int temp;
[COLOR="#FF0000"]  temp=(ADRESH<<8|ADRESL);  // combine 10 bit result [/COLOR]
return temp;
//display function
    while(adc)
		a[cnt++]=(adc%10);
		adc=(adc/10);
     while(cnt--)
While your code example may yield the expected results when compiled using the MikroC compiler,
it typically will not yield the expected result when compiled with a compiler more compliant with the C standards.
The issue is due to the statement highlighted in red:
The following part of the statement:
ADRESH<<8
Shifts the entire contents of the byte out, effectively clearing the byte.
A compiler compliant to the C standards would require you first cast ADRESH to a higher rank type, like an unsigned int, before shifting the contents eight place to the left.
Another, less used, but very powerful option would be to employ a type structure comprised of a union of a type unsigned int and two unsigned bytes.
typedef union{
unsigned int int_value;
struct{
    unsigned char hibyte;
    unsigned char lobyte;
}parts;
}int_convert;
Example Use:
     int_convert  adcvalue;
    adcvalue.parts.hibyte = ADRESH;
    adcvalue.parts.lobyte = ADRESL;
    unsigned int combinedvalues = adcvalue.int_value;
BigDog
Reactions: abv
    abv
this code working with hitech C
alternative code
temp=ADRESH;
temp<<=8;
temp|=ADRESL;
Reactions: abv
    abv
thanks for the code..
