Need a PS 120v 60Hz 4W input and 9V DC 100mA output
SensorDave
Newbie level 1
Newbie level 1
Hey all! First time posting. I need this specific application for my testing equipment at work. Any good sites for misc. adapters and power supplies?
Many thanks.
Dave
You need to build the circuit?
If so
Does it need to be 9V Regulated output or is unregulated ok?
Is the PSU to be current limited or anything else? (or just need to output at least 100mA)
Any other specs?
- Linear PSU or SMPS
- Line Regulation
- Load Regulation
__________________________________
or else
If your just after an off the shelf unit u should be able to find one quite easily. Just write a sheet with the specs u need and make sure the one you buy matches it.
I'm sure there are plenty of electronics shops that could help you out.
oddbudman
