need a help to find a sensor to measure Linear displacement
manojvalan
Junior Member level 1
Hi Friends,
I want to measure a linear displacement between two blades through that I can set the gap b/w them. Sensor range is 0-25mm and accuracy should be less than .01.I was searching for the sensor throughout the day. But I am not sure which one I can select for this. Please help me to find a suitable sensor for this application.
Thanks in advance.
Regards
Manoj
Re: need a help to find a sensor to measure Linear displacem
If the meter can contact the blades, you could use a digital micrometer (about $25.), which is able to read linear displacement, mechanicaly. They have a range of about 4 inches, can read out inches or mm, and have the resolution you specify. If no contact is allowed, but a reflector can be attached, you could use an optical interferometer, which has resolution of less than a micron. Or use a capacitive proximity sensor, which may be able to resolute at your spec. Depends on your budget and specifics of your application. Try googleing the one above that could work for your specs. Pat
    manojvalan
