Cool down FvM cool down...
i have attached an image file of my antenna design i've designed it using HFSS. its a hybrid structure of a slot coupled circular patch antenna with a surface mounted conical horn designed for 31GHz frequency with gain 12 db.A
microstrip circular patch is printed on a low permittivity 2.33 grounded substrate that is 0.7874 mm thick. The
patch is fed by a 50 ohm microstrip line on the backside of a
second 0.635-mm-thick dielectric layer with a higher permittivity of 10.22 through a rectangular coupling slot etched
in the ground plane.
dimensions are
W=15,L=20,Ws=.25,Ds=13,h1=.635,h2=.7874,Wf=.65,Lf=10.64,hc=7.875,rc=6.5,rp=1.48,Ls=2.3 all dimensions are in mm.
if you could further help me regarding it i'm pleased for your reply..!
if any other information regarding the design is needed please let me know.
