Need a current source about 100uA...1mA
H_u_n_t_e_r
Full Member level 2
Full Member level 2
National LM334 hasn't good tempco..
Im planning use it on 1000Ohm RTD sensor.
Regards.
Use sweap generators or Boot-Strab current source... the error is about 2~5% max... it's really powerfull...
i think you can use the following app.note.
circuit
have a look.. this is the design of bootstrab generator... you can have the current sourse from the diod and Q2 withoutr all other components... so that you do not have delta pulses of current... it's working.. i'm using this method.
Thanx to all reply..But %5 error too big.
There is another Current reference is REF200(from BurrBrown-Texas)
its excellent %0.5 error but difficult to find for me and expensive 5$ each...2.5$ for 1K...
Regards.
REF200
Hi H_u_n_t_e_r
I havent used this chip myself but if you like to try it and do not need so many, then try to get it as a sample. TI is really generous and you can have the chip within 3-4 days.
Good Luck
If you would like to get precision temperature measurements, maybe it would be better to use "poor" tempco current source, and connect RTD in series with stable resistor. Then measure resistor voltage drop, calculate current -> RTD -> temperature
regards
KamW
Hello!
I have intention to build similar aplication with NTC resistor. What do you think about use of voltage reference 2.5V?
Regards!
Check this!
Regards!
Reactions: yma-313
    yma-313
