Thanks Ian. Is there an advantage of one over the next? On a quick web search I found an IC that has a complementary transistor pair that I can use, but am not entirely sure how to wire this on the datasheet or your diagram.
V-in (signal) would be at the base of the transistors right? Is V-out between the emitter of the first and collector of the second? Basically, I'm not sure about anything else either in terms of practically wiring this. The supply voltage, presumably ~12V would be at the top supplying the first collector with ground after the second at the pnp?
Sorry. Told you I was a newb. STS01DTP06 is an IC that I found on the web that has a complementary pair on board, but not sure what to make of all it's specifications for my application. This thing is only 5mm! I think I'd have a difficult time soldering that.
