djalli
Advanced Member level 3
- Joined
- Nov 10, 2001
- Messages
- 825
- Helped
- 31
- Reputation
- 62
- Reaction score
- 15
- Trophy points
- 1,298
- Activity points
- 8,284
I have signals 1Volts p-p roughly with very low frequencies 0.5-5Hz. Can I convert them to square wave signals with the same frequency as original signal is.
example as:
-If signal is sinusoid 1volts p-p 2hz to make at ouput a square wave also 2hz in frequency ---or
-If signal is triangle 1.2volts p-p 1.5hz to make at ouput a square wave also 1.5hz in frequency
Can I make a circuit out of it or is any precision IC exactly for this purpose out there?
thousands of thanks to all of you
example as:
