when i am running ncxlmode in linux, some error happens:
ncvlog: *F,DLNFS: Packed library for 'worklib' was either corrupt or the file system cache consistency check failed. To correct the problem, remove the packed library, and recompile. If the problem persists, contact Cadence Design Systems.
ncxlmode: *E,VLGERR: Error during parsing (status 2), exiting.
i tried remove INCA_lib and re-run...still....problem
ncxlmode: *E,VLGERR: An error occurred during parsing. Review the log file for errors with the code *E and fix those identified problems to proceed. Exiting with code (status 2).
