NCVerilog installation and setenv help
aravind
Advanced Member level 1
india
ncverilog license
hi friends
i m having NCVerilog.tar.gz file and it license.when i untar it i get 4 folder tools,- tools.ln86, -doc,- share. i sentenv for it . but it was running nclaunh but when i type "verilog -gui" command it show error message
ERROR! can't determine installation root from PATH
System! Source file "gui" cannot be opened for reading [Verilog-SFCOR]
what can i do.
note :i set this env
csh
setenv PATH {$PATH}:/root/NCVerilog/tools.lnx86/bin
setenv PATH {$PATH}:/root/NCVerilog/tools.lnx86/dfII/bin
setenv PATH {$PATH}:/root/NCVerilog/tools.lnx86/nclaunch/bin
setenv PATH {$PATH}:/root/NCVerilog/tools.lnx86/verilog
setenv CDSDIR /root/NCVerilog
setenv CDS_ROOT /root/NCVerilog
setenv CDS_INST_DIR /root/NCVerilog
setenv CDS_INSTALL_DIR /root/NCVerilog/tools.lnx86/dfII
setenv CDS_INSTALL_DIR /root/NCVerilog/tools.lnx86/nclaunch
setenv CDS_LIC_FILE 5280@localhost.localdomain
setenv CDS_Netlisting_Mode Analog
cd ..
/tools/cds5/tools.lnx86/bin/lmgrd -c license5.dat
one more question i run license file of ic5 for NCVerilog .how to run for ncverilog and how t o setenv?
thanks
error-[sfcor]
setenv command can be typed after typing "csh" in your bash prompt in terminal, and as for your other queries, i think you are in the right track for setting the environment variable. HOPE YOU GOT OVER THE PROBLEM AND CURRENTLY WORKING WITH NCVERILOG
cadence nc verilog + tar
you can try " ncverilog " command to make sure setting ok or not
good luck
ncverilog install path
hi
i try nclaunch .it is working .but when i run ncsim my system is hands
ncverilog licence installation
u shuold export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:nc_dir/tools/lib
and mv /lib/tls /lib/tls.bak
run nc verilog in linux
hi
i install ic5 in my redhat 8.0 then i upgrate to redhat 9.0 following instruction posted before.
but im facing problem
errors:
" Incorrectly built binary which accesses wrrno,h_errno or _res directly.needs to be fixed"
"8 bit pseduocolor visual is not avaible(default visual option)
using 24 bit truecolr visual"
warning:cannot convert string "-adobe-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type fontstruct"
thsi r the errors coming pls help me correct it
thanks
nc verilog linux command
hi aravind
where can get the NCVerilog.tar.gz ?
irun ncverilog
Hi !!!
1. If NCVerilog has been installed locally, then not start lmgrd.
2. Set variables CDS_LIC_FILE and PATH if it is not set
export CDS_LIC_FILE=/......
export PATH=$PATH:/.../NCVerilog/bin
Added after 2 minutes:
I am know that NCVetilog it a part LDV
index of ncverilog
hi, you must make a link just like
'ln -s tools.lnx86 tools'
