Hi ,
Actually moving from SUN to Linux is not an alternative ,
Same problem i faced during my sims,
U please check ur arrays and pointer initialisation , as some variable is not getting memory .
suppose u initialise a variable as s[6] and u are using from s[8] -> s[0] then it will give seg fault,
Linux machines are faster than SUN machines , so better see ur code, rather than shifting to different OS.
regards
spauls
