nChip (ATMEGA64 and 128): cheap ppp systems
G
Newbie level 1
easy tcpip
has anyone played around with a nChip (ATMEGA64 and ATMEGA128)?
a really cheap ppp system from h**p://www.nChip.com
Re: easy tcpip
I've tried with unet serial emulator first to ensure it works...
what are you working on?
Re: easy tcpip
I have no found about DHCP on this. Does this support it?
Re: easy tcpip
What did you mean of DHCP???
It's serial PPP TCP/IP Stack
Re: easy tcpip
DHCP = Dynamic Host Configuration Protocol, usually used in LAN for PCs to obtain ip's dynamically.
easy tcpip
@Paul_Sh
And what is the argument for suggesting that UDP Port 67/68 shouldnt be used on PPP ??
DHCP is used at linklevel to assign ip addr , dns , domain name etc.
Also for PPP
/Bingo
