It's possible but there are some constraints.Thanks for reply
Do simulation works (ADS or any other tool)? I was able to make filter using smd inductor and capacitors (0805). Q of inductor was around 60 to 80.
Another issue is hand effect while tuning ver-caps.
I need a sharp band (few 10Khz) 40 MHz filter with simple design (3rd order).
In other words Q ≈ 1000. That's not feasible with intended design techniques. L quality factor is the critical point, C with Q>1000 is at least feasible (NP0 can do, mica is optimal).I need a sharp band (few 10Khz) 40 MHz filter with simple design (3rd order).
