nanosim simulation problem
wjlzhx
Member level 5
Member level 5
setenv ld_library_path nanosim
Hi :
I want to run Nanosim in analog environment,so i use specte's netlist to run Nanosim,but now i got problem.
the problem is that:
FATAL:Nanosim:0x4110a25d:Custom output format:library /ecad/ns_spearc0S5
/sparc0S5/ns/lib/nass_psf.so is missing under directory ./ or LD_LIBRARY_PATH
and cannot be opend
in fact ,in ecad/ns_spearc0S5/sparc0S5/ns/lib there is a file nass_psf.so ,and in
LD_LIBRARY_PATH i had add
setenv LD_LIBRARY_PATH ecad/ns_spearc0S5/sparc0S5/ns/lib
So what happend to it ???
please help me
thanks !!!!
is anybody kow ????
I want to plot in candence's waveform ,so the output file is .psf
but now there is some error.
please help me
Hello,
Which command do u use it to run nanosim ??
a+
it generat by itself if i use nanosim in analog artist
"set_print_format for=psf lib_name = nass_psf.so"
Halo,
I also facing the same fatal here.
FATAL:NanoSim:0x4110a25d:custom output format: library libtr0.so is missing under directory ./ or LD_LIBRARY_PATH and cannot be opened. (dlerror: "libtr0.so: cannot open shared object file: No such file or directory")
Can I know how you solve it?
Thanks.
Rdgs
TOK
