Paul98
Member level 5
Hello, where is the problem in the circuit in the picture? I replicated the same schematic on LTspice (.asc renamed to .txt) and I have not encountered any kind of problem.Thanks
Hi,The resistor between AC to ground does not have succes.
Hi,now i can't post the schematic file. Can you do with the image on post 3 and 5? I never seen the problem on LTspice.Hi,
show the schematic.
LTspice has similar problem.
Klaus
Can you? ... verify whether the 10M resistor is correctly connected?Can you do with the image on post 3 and 5?
