little-gummibaer
Newbie level 3
![Newbie level 3](/styles/images/ranks/alevel3.gif)
hi
I need the names of codes which are constructed as follows:
The code always has the same number of zero and one example: 010110 is a corect codeword 110000 is not an corect codeword
is the code bild as 2/4 code is the code tabelle:
data codeword
00 - 0011
01 - 0101
10 - 0110
11 - 1001
has you seen this before in need the name or the name of codierungs typ
of course an 2/4 makes no sence it is only for an easy example
i hope someone con help me
little
data codeword
00 - 0011
01 - 0101
10 - 0110
11 - 1001
little
