Mystery component in motor speed controller
Newbie level 3
This circuit is a 240 volt motor speed controller. There's a missing component (blank space above the triac), which looked like a zener diode, but it melted, so I can't identify it. I've tried diodes, thermistors, and diacs, but the motor only runs at top speed, or not at all. Can anyone tell me what the missing component should be?
Hi.
I´m sure it was a diac.
If the motor still spins full RPM, then something else is defective (which makes sense, because the diac should not die alone)
Klaus
Hi.
Klaus
Thanks Klaus,
I replaced the triac just in case (although it tested fine), and I've also replaced C1, which leaked a little when I put 500v across it. Since replacing C1, I have an open circuit. No movement from the motor.
LaTeX Commands Quick-Menu:
