mysterious equation e^jwt
david753
Full Member level 1
Full Member level 1
e^jwt
As you know, e^jwt=cos(wt)+j*sin(wt)
I can plot its diagram by mathlab.
And get the result of a sinusoidal.
But, when I try another numers, 2 or 3 instead of e in above equation.
The result is still like sinusoidal.
How to explain it?
j is key point, and j=sqrt(-1).
It is really beyond my imagination.
e jwt
if you visualise the numbers u substitute say 2 or 3 as e^k you will realise that you are just multiplying e^jwt by a constant and hence you are just multiplying a sine wave with a constant and hence will obtain a sinusoid only....
mysterious equation
Well, this question, you are anxious about, is not so strange as it probably seems to you. The explanation of this circumstance is the followin:
1) Remember the main logarithmic identity, studied in the school course of algebra:
e^(ln(a)) == a, if a>0. Now let's apply this expression to your example:
2^(jwt) = e^(ln(2^(jwt))) = e^(iwt*ln(2)) = exp(jwt*ln(2)).
2) Now we simply adjust the Euler formula, which you mentioned, to exp(jwt*ln(2)) and get the following:
exp(jwt*ln(2)) = cos (wt*ln(2)) + j * sin(jwt*ln(2)).
So as you see again we obtained harmonic functions, which represent real and imaginary parts correspondingly. The 90 degrees phase shift preserves, the only difference - is that these functions are scaled (compressed, respectively the x-axis).
It's obvious, that any substitution of e doesn't change the sense.
With respect,
Dmitrij
e(jwt)
When I type 2^(sqrt(-1)) in mathlab, I can get sinusoid figure.
But, how is it souce code?
e^-jwt
well it is just based on the individual function i.e.sqrt and the exponentiation(^)
the code of can be seen by using help.....
