Soh_bhat
Junior Member level 1
I am working on a project where I am using some IP cores of floating point with latency 3. What I am doing is there is some specified value of x_in, y_in, h, p_in, p1_in, c_in and it will do the operations using a module that has some floating point operation. The first iteration is coming as expected. Point is the x_out and y_out value of the first iteration will be stored as the next iteration's x_in and y_in and generate the result. The storing is happening but it is not giving the expected output from the second one onwards. Don't know if I am writing the test bench wrong. Please let me know. But the values come with latency 0 as it has no clock. Please check the test bench along with the waveform.
-- Company:
-- Engineer:
-- Create Date: 02/26/2023 08:02:34 PM
-- Design Name:
-- Module Name: Top_TB - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Top_TB is
-- Port ( );
end Top_TB;
architecture Behavioral of Top_TB is
component Top is
Port (
clock: in std_logic;
inst: in std_logic_vector(31 downto 0);
cont: out std_logic_vector(31 downto 0);
addr: out std_logic_vector(11 downto 0);
x_out: out std_logic_vector(31 downto 0);
y_out: out std_logic_vector(31 downto 0);
x_in: out STD_LOGIC_VECTOR(31 downto 0);
y_in : out STD_LOGIC_VECTOR(31 downto 0);
h : out STD_LOGIC_VECTOR(31 downto 0);
p_in : out STD_LOGIC_VECTOR(31 downto 0);
p1_in : out STD_LOGIC_VECTOR(31 downto 0);
c_in : out STD_LOGIC_VECTOR(31 downto 0);
initial_flag: out std_logic;
-- init_flag: in std_logic;
initial: out std_logic;
cma_out: inout std_logic_vector(11 downto 0)
end component;
signal clock: std_logic := '0';
signal cont: std_logic_vector(31 downto 0);
signal inst: std_logic_vector(31 downto 0);
signal addr : std_logic_vector(11 downto 0);
signal initial_flag: std_logic;
signal x_in: STD_LOGIC_VECTOR(31 downto 0);
signal y_in : STD_LOGIC_VECTOR(31 downto 0);
signal h : STD_LOGIC_VECTOR(31 downto 0);
signal p_in : STD_LOGIC_VECTOR(31 downto 0);
signal p1_in : STD_LOGIC_VECTOR(31 downto 0);
signal c_in : STD_LOGIC_VECTOR(31 downto 0);
signal initial: std_logic;
signal cma_out: std_logic_vector(11 downto 0);
signal x_out: STD_LOGIC_VECTOR(31 downto 0);
signal y_out : STD_LOGIC_VECTOR(31 downto 0);
constant clock_period : time := 10 ns;
begin
uut: Top port map (
clock => clock,
inst => inst,
initial_flag => initial_flag,
cont => cont,
addr => addr,
x_in => x_in,
y_in => y_in,
h => h,
c_in => c_in,
p_in => p_in,
p1_in => p1_in,
initial => initial,
x_out => x_out,
y_out => y_out,
cma_out => cma_out
clk_process rocess
begin
clock <= '0';
wait for clock_period/2;
clock <= '1';
end process clk_process;
proc: process
begin
--write_en <= '1';
inst <= "000000000000" & "00001" & "000" & "00000" & "0001100";
wait for clock_period;
--write_en <= '1';
inst <= "000000000100" & "00010" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000001000" & "00011" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000001100" & "00100" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000010000" & "00101" & "000" & "00000" & "0001100";
--write_en <= '1';
inst <= "000000010100" & "00110" & "000" & "00000" & "0001100";
--wait for clock_period * 50.5;
inst <= "000000000000" & "00001" & "101" & "00000" & "0001100";
wait for clock_period * 45;
--wait for clock_period * 14;
--wait for clock_period * 51;
inst <= "000000000000" & "00001" & "001" & "00000" & "0001100";
inst <= "000000000000" & "00001" & "100" & "00000" & "0001100";
wait;
end process;
end Behavioral;
Please help.
-- Company:
-- Engineer:
-- Design Name:
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
library IEEE;
--library UNISIM;
entity Top_TB is
-- Port ( );
end Top_TB;
component Top is
Port (
end component;
begin
uut: Top port map (
clock => clock,
inst => inst,
cont => cont,
addr => addr,
x_in => x_in,
y_in => y_in,
h => h,
c_in => c_in,
p_in => p_in,
p1_in => p1_in,
initial => initial,
x_out => x_out,
y_out => y_out,
cma_out => cma_out
clk_process rocess
begin
clock <= '0';
clock <= '1';
proc: process
begin
--write_en <= '1';
--write_en <= '1';
--write_en <= '1';
--write_en <= '1';
--write_en <= '1';
--write_en <= '1';
wait;
end process;
end Behavioral;
Please help.
