pgib8
Member level 2
This guy on youtube drives me crazy, he says that reflected power does not go back to the transmitter and that the transmitter doesn't see the reflection. I disagree with him so he deleted my comment at first until I tell him again with a different account. The worst part is he's pretending to educate people, dispelling myths apparently. He says "true: reflected power does not flow back into the transmitter and cause damage".
I ask him among other things: how come after accidentally transmitting a bunch without having an antenna connected, that my radio stopped producing power.
He answers:
"You blew up your rig because you were transmitting into an open circuit. The rig is designed to transmit into a 50 ohm load. An open circuit presents a huge impedance mismatch to the output stage so it overheated and failed. It had nothing to do with reflected power..."
He tells me "It's a complex subject and it will take a while to wrap your head around it. If you really want to understand this stuff it takes some time and effort."
and "You gotta do some reading."
Another thing he says: "When reflected power encounters a mismatch at the load, its phase is reversed and heads back to the transmitter, where it encounters a large impedance mismatch so is totally reflected back to the load where it is eventually radiated."
So what I think is that this guy doesn't understand impedance like at all, I'm not sure he's ever seen a smith chart let alone know what it means.
Here is a link to his channel but I recommend you don't go there because it will probably make you mad: youtube.com/@NoMoreRadioMyths (K3ZD, Mark the Ham Florida Man).
He answers:
