wickedweasel
Member level 1
Dear all,
I was able to make the attach file (which is a simulation of microwave oven) more efficient by changing the parameters.
It consists of two parts: waveguide and cavity.
If you investigate the waveguide and cavity seperately (one by one);
I have a efficient waveguide with -30 dB s1.
and my cavity itself has resonant dimensions at 2.45 GHZ.
They are both working good themselves.
When I connect them it seems they dont work.s1 becomes 0.
This is my problem.
I think I can overcome this problem by two ideas:
1-)To put a material inside the cavity that is able to absorb power (like a potatoe)
But i dont know the permittivity, permeability of it.
When i tried to put some material arbitrarily it seems that the s1 parameter makes some difference.I was able to get -1 dB instead of 0 which is again too high.
I try to get -10 dB at least.
Can anyone tell me what material to put inside the cavity to get a good result???
2-)The best mode that works with my system is TE 564.
I dont know how to tell HFSS to excite the waveguide by this mode.
can you help me about these two topics?
This is my problem.
