my cadence cannot simulate...
zhangjavier
Full Member level 1
could not open ahdlcmi module library
after install the PDK, i draw a schematic, but when i simulate it, the following messages appear.
Opening directory
/.../..../............./rvar_mos_varactor.va.adhlcmi/
Compiling ahdlcmi module liabrary
Failed to compile ahdlcmi module library, see /.../.../....... for details
Couldnot open ahdlcmi module library
can not open shared file: no such file or directory
Error found by spectre during circuit read-in
input.scs: C0 is an instance of an undefined model pip.
sprectre terminated prematurely due to fatal error
How can I solve this problem ? Please help me ~~
failed to compile ahdlcmi module library
You need a capacitor model named pip. If you don't have pip model, try to use ideal capacitors -- leave the model name of capacitors blank, and set the capacitor values.
fail to compile ahdlcmi module library
Please help to check the version of cadence IC.
if the version is 5.10.41.169, there will have this error message.
The solution is to upgrade to 5.10.41.500.
cannot compile ahdlcmi module library.
rite
