[SOLVED] My Bi Polar Power Supply Problem
gerbster
Newbie level 2
Newbie level 2
I'm working on a small bi polar power supply capable of supplying +/- 12 VDC. I found a couple of schematics on the web, but this one comes very close:
However, I've run into some problems ;-) For some reason the 7912 IC is not giving me the requested -12 VDC. This is what i have so far:
Voltages:
Input: 19 VAC (from an old clock radio transformer)
Across Point 1 & 2: +/- 25Vdc
With the 2 Ic's omitted:
Across Point 4 & 5: -12.8 Vdc
Across Point 3 & 5: +12.8 Vdc
With the 2 Ic's installed:
Across Point 4 & 5: -5.8 Vdc
Across Point 3 & 5: +18.6 Vdc
Across Point 5 & 6: -5.5 Vdc
Across Point 5 & 7: +11.8 Vdc
So for some reason, with the 7812 & 7912 in place the voltage isn't diveded evenly between C1 & C2 anymore. Does anyone have any pointers on this?
Thanks in advance!
I'm guessing you didn't connect point 5 to the transformer centre tap (as you can see in the circuit diagram). That is the problem.
