[SOLVED] MWO - EM Structure missing
RFGuy90
Newbie
Newbie level 2
Can someone help me with adding the EM Structure to the Project tab? I'm jumping into using MWO for the first time.
What kind of EM structure you attempt to import ?? Planar ? Or -for instance- a PCB ??
You should either import your structure into MWO as DXF or Gerber or PCB format then you define the others.
OR
You draw your own planar structure by defined Microstrip/Strip Lines the extract the on layout.
It turns out I had more of an IT issue. I had to use a different license to have the EM capability. Closing the thread now, thanks for you answer!
