MWO AWR move trace
MamadJun
Junior Member level 2
Belgium
Hey all,
I am using AWR MWO to do some system simulations with VSS. My main question is about using data and modifying them.
So finally I have the result DB(C_GT(...))
I also plotted two maskes upper and lower that are around 0 dB.
The problem is that the DB C_GT is not around 0 db so I had to use an attenutor at the end to adjust the shape of the reposne between two masks.
I need to chnage some varaibles in the design so the trace keeps chnaging and I have to manually chnage the attenuator value to adjust the tarce again. As you see this is a very in efficient way to plot sopmething very simple!!!
Question:
I wonder if there is a way to normalize/ adjust this trace automitcally? (e.g., change the gain at 26.25 GHz so it is set to 0 dB)
