dizgah
Member level 5
Hi every one,
Consider the following codes:
As far as I've noticed from RTOS's scheduling ,RTOS assign a specific time to each task and after this time is over,it switches to the other task.
Then in this specific time,inside task's infinite loop ,maybe loop is repeated several times until task's specific time finished.
Assume task is finished in less than of it's time's half,then it has a time to fully run this task once again :
in last line after releasing mutex , then it will achieve mutex before than task2 for second time,Am I true ?
assume timer tick occur when MCU run Thread1_Functions for second time,then task2 cant run because mutex owned by task1, RTOS run task 1 again and if timer tick occur every time in the Thread1_Functions, then task2 has no chance to running,Am I true ?
First Thread
void Thread1 (void const *argument)
for (;;)
osMutexWait(mutex, osWaitForever);
Thread1_Functions;
osMutexRelease(mutex);
Second Thread
void Thread2 (void const *argument)
for(;;)
Thread2_Functions;
