torinwalker
Newbie level 6
Hi Everyone.
I'm presently designing in ESD/EMI protection ICs for all the interfaces I suspect may be subject to ESD and/or will be susceptible to noise, or contribute to noise propagation. The design is a simple PDA device contained by an ABS/PC shell with the following interfaces:
- resistive touchscreen
- on/off button (insulated from user by mould-injected plastic pushbutton)
- reset button (also insulated by a pushbutton)
- receiver (i.e. telephone earpiece)
- loudspeaker
- microphone
- audio/mic (headset) jack
- micro SD
- SDIO
- USB
Of all the interfaces, I see six items that may not require ESD/EMI protection, but then I'll take any reasonable argument to the contrary. The resistive touchscreen is plastic, the loudspeaker, receiver and mic are separated from the user by the plastic case through holes that (I believe) would be unlikely to permit an ESD jump from placing it near one's ear, etc. - primarily because one must pick up the device to do so, and the buttons are insulated by several mm of plastic. Also not likely to conduct.
I'm not so sure about the touchscreen though. It is quite likely that someone will shuffle across the floor, reach over, and touch the screen before picking up the device, in which case ESD transients would be suppressed by a protection device.
All the others - particularly the USB, Audio, and SD interfaces should obviously have ESD built in. Luckily, ESD is built into the USB transceiver I'm using.
Secondly, since many devices combine ESD with EMI filtering, perhaps it makes sense to protect all interfaces that may pick up on noise with the added security of ESD protection. This may help reduce errors induced by noise. Could it help with EMI testing later on? What about Federal EMI certification (Canada/US)?
What are your thoughts on this? Every chip costs between 0.30 cents up to more than a buck per IC. At this rate, I'll have added nearly $10 to the base cost which translates to added cost the user will likely not perceive as value add.
I will add these devices, but not merely because the people who manufacture them managed to find ways to describe every imaginable situation where their devices are a must-have in one's electronic design. Surely there must be a line drawn somewhere between devices that actually are necessary, and ones where -- perhaps -- the manufacturer is stretching the ESD/EMI protection story a little bit.
Thanks, guys (and gals). I appreciate any help you can offer.
Torin...
- loudspeaker
- microphone
- micro SD
- SDIO
- USB
Torin...
