km99
Newbie level 1
Can someone please explain me this matlab code here for angle of arrival estimation in DETAIL.
Please explain to me all the steps of the code as I am not able to understand it. It will be very helpful for me.
Thank You.
%CODE FOR MUSIC ALGO FOR DOA
clear all;
close all;
clc;
% TRANSMITTED SIGNALS %
% Signal source directions
az =[50;70;90] % angles
el = zeros(size(az)); %
M = length(az); % Number of sources
% Transmitted signals
L = 100; % Number of data snapshos recorded by receiver
rng('default'); %for same random generaor
m = randn(M,L); % normally disributed random signals
% ========= (2) RECEIVED SIGNAL ========= %
% Wavenumber vectors (in units of wavelength/2)
k = pi*[cosd(az).*cosd(el), sind(az).*cosd(el), sind(el)].';
% Array geometry [rx,ry,rz]
N = 10; % Number of antennas
r = [(-(N-1)/2:(N-1)/2).',zeros(N,2)]; % Assume uniform linear array
% Matrix of array response vectors
A = exp(-1j*r*k);
% Additive noise
sigma2 = 0.01; % Noise variance
n = sqrt(sigma2)*(randn(N,L) + 1j*randn(N,L))/sqrt(2);
% Received signal
x = A*m + n;
% ========= (3) MUSIC ALGORITHM ========= %
% Sample covariance matrix
Rxx = x*x'/L;
% Eigendecompose
[E,D] = eig(Rxx);
[lambda,idx] = sort(diag(D)); % Vector of sorted eigenvalues
E = E(:,idx); % Sort eigenvalues accordingly
En = E(:,1:end-M); % Noise eigenvectors (ASSUMPTION: M IS KNOWN)
% MUSIC search directions
AzSearch = (0:1:180).'; % Azimuth values to search
ElSearch = zeros(size(AzSearch)); % Simple 1D example
% Corresponding points on array manifold to search
kSearch = pi*[cosd(AzSearch).*cosd(ElSearch), sind(AzSearch).*cosd(ElSearch), sind(ElSearch)].';
ASearch = exp(-1j*r*kSearch);
% MUSIC spectrum
Z = sum(abs(ASearch'*En).^2,2);
% Plot
figure();
plot(AzSearch,10*log10(Z));
title('Simple 1D MUSIC Example');
xlabel('Azimuth (degrees)');
ylabel('MUSIC spectrum (dB)');
grid on; axis tight;
%END OF CODE
Thank You.
