Multisim 2001 XPSP1 DAO/Jet problem
Homosezwhat?
Newbie level 6
Newbie level 6
location, location!!
multisim dao
Anyone had a problem with running MS 2001 under XP SP1 ? When I try to start MS now, it sez " Unable to initialize DAO/JetDB engine" and quits.
multisim 10 dao
what you need to do
is apply sp1 to multisim also
if you use sp1 xp corperate version
also
the correct sequence of install is in order of release date
and must all go in every update
the error you have is a data object error
the jet doa engine is installed by multisim when it runs for the first time
it will ask you if you want to update this
if you use forinstance win 98 this is a work around in the set up for multisim
to prevent the doa engine installing in xp {becouse it has a later version}
this database is linked by data object access to other platforms like office etc.... for export and spreadsheet type work on the data base
so my advice is to
uninstall the app completely remove all dead folders and other parts
reboot
and then use an app like system mechanic too clean and remove all the dead keys
then reboot
and reinstall this time it will ask say yes
then let it figure out the doa is already there and install the correct flags and files for xp
then register the app and install sp1 too it then update the database
