acicsok
After a lot of searching, I have found some similar threads but not the solution for my problem. I have two 2.3" common anode displays and I want to multiplex them and I made some circuit but it don't work. The problem is that displays are blinking, refresh rate is 60 Hz measured few times. P-channel mosfet for high side switching is BS250 and NPN transistor is 2n3904. Sorry for my bad English and I am hoping that someone can read my schematic that is attached on post.
Thank you for help.
P.S. Microcontroller is used to drive all elements.
Thank you for help.
