guardspecialone
Junior Member level 1
- Joined
- Nov 13, 2015
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 171
Hi
I want to multiplex (9) nine 7-seg displays (common anode). My PIC can source/sink maximum 18mA on each digital I/O pin but the display I am using is rated at 30mA
Question is:
Can I use only 9 mosfets on high side or I have to also use 8 mosfets on low side?
* (9) nine P-CHANNEL mosfets (high side) will control each display (on/off)
* (8) eight N-CHANNEL mosfets (low side) will control each segment (A, B, C, D, E, F, G, DP)
Each display segment only draw around 4mA (4*8=32mA total) of current. Display anode will be powered with mosfet from 5V USB line. In this case, is it safe to wire segments directly to PIC or I must also use mosfets on low side to connect segments to GND instead?
Can someone give me the answer please.
Question is:
