goatmxj666
Member level 3
Hello,
I designed current-mode BGR in cadence and output voltage is 2V.
I need reference voltages: 0.5V, 0.7V, 1V, 1.5V, 2V
So I wonder how can I make those reference voltages with my BGR?
my plane is just using resistor divider at the output voltage node.
or using 4 current mirror with pmos which is located at output stage of BGR, and adjust mirroring ratio & resistor values for each voltages. (0.5V, 0.7V, 1V, 1.5V)
I would be very appreciated if you give me some tips for how to deal with BGR for actual circuits that need reference voltages, such as 0.5V, 0.7V, 1V, 1.5V, 2V!
Thanks
Thanks
