milan.rajik
Banned
This is Multiple I2C LCD code. It is written using CCS C Compiler version 5.044. This si tested in Proteus and also EasyPIC v7 development board with 2 x 20x4 LCDs. LCDs should be HD44780 or compatible. I have used I2C LCDs and I2C LCD modules from Banggood.
I will soon post mikroC PRO PIC and AVR versions of the code here.
With this you can have 8 LCDs. Any combination of 16x2, 20x2 and 20x4.
If you have I2C device like DS1307 then you can have 7 LCDs.
Sorry, DS1307 address is fixed and it is 0xD0. So, You can have DS1307 or any other I2C device with fixed I2C address and also 8 LCDs to display different datas.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 #define _LCD_FIRST_ROW 0x80 //Move cursor to the 1st row #define _LCD_SECOND_ROW 0xC0 //Move cursor to the 2nd row #define _LCD_THIRD_ROW 0x94 //Move cursor to the 3rd row #define _LCD_FOURTH_ROW 0xD4 //Move cursor to the 4th row #define _LCD_CLEAR 0x01 //Clear display #define _LCD_RETURN_HOME 0x02 //Return cursor to home position, returns a //shifted display to its original position. //Display data RAM is unaffected. #define _LCD_CURSOR_OFF 0x0C //Turn off cursor #define _LCD_UNDERLINE_ON 0x0E //Underline cursor on #define _LCD_BLINK_CURSOR_ON 0x0F //Blink cursor on #define _LCD_MOVE_CURSOR_LEFT 0x10 //Move cursor left without changing //display data RAM #define _LCD_MOVE_CURSOR_RIGHT 0x14 //Move cursor right without changing //display data RAM #define _LCD_TURN_ON 0x0C //Turn Lcd display on #define _LCD_TURN_OFF 0x08 //Turn Lcd display off #define _LCD_SHIFT_LEFT 0x18 //Shift display left without changing //display data RAM #define _LCD_SHIFT_RIGHT 0x1E //Shift display right without changing #define LCD_RS PIN_B4 #define LCD_EN PIN_B5 #define LCD_D4 PIN_B0 #define LCD_D5 PIN_B1 #define LCD_D6 PIN_B2 #define LCD_D7 PIN_B3 #define EN_DELAY 100 #define LCD_STROBE {output_high(LCD_EN); delay_us(EN_DELAY); output_low(LCD_EN); delay_us(EN_DELAY);}; #define Waddr1 0x4E #define Waddr2 0x4C void I2C_LCD_Cmd(char address, char out_char); void I2C_LCD_Chr(char address, char row, char column, char out_char); void I2C_LCD_Chr_Cp(char address, char out_char); void I2C_LCD_Init(char address); void I2C_LCD_Out(char address, char row, char col, char *text); void I2C_LCD_Out_Cp(char address, char *text); void CustomChar(char address, char pos_row, char pos_char); char msg1[] = "I2C LCD 4 Bit"; char msg2[] = "PIC18F46K22 8 MHz"; char msg3[] = "CCS C, EasyPIC v7"; char msg4[] = "LCD address 0x07"; char msg5[] = "LCD address 0x06"; char const msg6[] = "Const Text Test"; char const character[] = {10,21,17,10,4,0,0,0}; /* LCD_I2C found with PCF8574 P7,P6,P5,P4 of PCF8574 = MSbits DB7,DB6,DB5,DB4 of LCD Display. P3 is hardware display bit (BackLight : 1 = on / 0 = off) P2 is hardware E display bit clock : E = 1 -> E = 0 active P1 is R/W hardware Read/Write bit hardware : Read = 1 / Write = 0 P0 is RS hardware Register Select : CmdReg = 0 / DataReg = 1 */ void I2C_LCD_Cmd(char address, char out_char) { char hi_n, lo_n; char rs = 0x00; hi_n = out_char & 0xF0; lo_n = (out_char << 4) & 0xF0; I2C_Start(); I2C_Write(address); I2C_Write(hi_n | rs | 0x04 | 0x08); delay_us(50); I2C_Write(hi_n | rs | 0x00 | 0x08); delay_us(100); I2C_Write(lo_n | rs | 0x04 | 0x08); delay_us(50); I2C_Write(lo_n | rs | 0x00 | 0x08); I2C_stop(); if(out_char == 0x01)Delay_ms(2); } void I2C_LCD_Chr(char address, char row, char column, char out_char) { char hi_n, lo_n; char rs = 0x01; switch(row){ case 1: I2C_LCD_Cmd(address, 0x80 + (column - 1)); break; case 2: I2C_LCD_Cmd(address, 0xC0 + (column - 1)); break; case 3: #ifdef LCD16X4 I2C_LCD_Cmd(address, 0x90 + (column - 1)); #else I2C_LCD_Cmd(address, 0x94 + (column - 1)); #endif break; case 4: #ifdef LCD16X4 I2C_LCD_Cmd(address, 0xD0 + (column - 1)); #else I2C_LCD_Cmd(address, 0xD4 + (column - 1)); break; }; hi_n = out_char & 0xF0; lo_n = (out_char << 4) & 0xF0; I2C_Start(); I2C_Write(address); I2C_Write(hi_n | rs | 0x04 | 0x08); delay_us(50); I2C_Write(hi_n | rs | 0x00 | 0x08); delay_us(100); I2C_Write(lo_n | rs | 0x04 | 0x08); delay_us(50); I2C_Write(lo_n | rs | 0x00 | 0x08); I2C_stop(); } void I2C_LCD_Chr_Cp(char address, char out_char) { char hi_n, lo_n; char rs = 0x01; hi_n = out_char & 0xF0; lo_n = (out_char << 4) & 0xF0; I2C_Start(); I2C_Write(address); I2C_Write(hi_n | rs | 0x04 | 0x08); delay_us(50); I2C_Write(hi_n | rs | 0x00 | 0x08); delay_us(100); I2C_Write(lo_n | rs | 0x04 | 0x08); delay_us(50); I2C_Write(lo_n | rs | 0x00 | 0x08); I2C_stop(); } void I2C_LCD_Init(char address) { char rs = 0x00; I2C_Start(); I2C_Write(address); delay_ms(30); I2C_Write(0x30 | rs | 0x04 | 0x08); delay_us(50); I2C_Write(0x30 | rs | 0x00 | 0x08); delay_ms(10); I2C_Write(0x30 | rs | 0x04 | 0x08); delay_us(50); I2C_Write(0x30 | rs | 0x00 | 0x08); delay_ms(10); I2C_Write(0x30 | rs | 0x04 | 0x08); delay_us(50); I2C_Write(0x30 | rs | 0x00 | 0x08); delay_ms(10); I2C_Write(0x20 | rs | 0x04 | 0x08); delay_us(50); I2C_Write(0x20 | rs | 0x00 | 0x08); I2C_Stop(); delay_ms(10); I2C_LCD_Cmd(address, 0x28); I2C_LCD_Cmd(address, 0x06); } void I2C_LCD_Out(char address, char row, char col, char *text) { while(*text) I2C_LCD_Chr(address, row, col++, *text++); } void I2C_LCD_Out_Cp(char address, char *text) { while(*text) I2C_LCD_Chr_Cp(address, *text++); } void CustomChar(char address,char pos_row, char pos_char) { char i; I2C_Lcd_Cmd(address, 64); for (i = 0; i<=7; i++) I2C_Lcd_Chr_Cp(address, character[i]); I2C_Lcd_Cmd(address, _LCD_RETURN_HOME); delay_ms(2); I2C_Lcd_Chr(address, pos_row, pos_char, 0); } void main() { I2C_Speed(100000); I2C_LCD_Init(Waddr1); I2C_LCD_Cmd(Waddr1,_LCD_CURSOR_OFF); I2C_LCD_Cmd(Waddr1,_LCD_CLEAR); I2C_LCD_Init(Waddr2); I2C_LCD_Cmd(Waddr2,_LCD_CURSOR_OFF); I2C_LCD_Cmd(Waddr2,_LCD_CLEAR); I2C_LCD_Out(Waddr1,1,1,msg1); I2C_LCD_Out(Waddr1,2,1,msg2); I2C_LCD_Out(Waddr1,3,1,msg3); I2C_LCD_Out(Waddr1,4,1,msg4); I2C_LCD_Out(Waddr2,1,1,msg1); I2C_LCD_Out(Waddr2,2,1,msg2); I2C_LCD_Out(Waddr2,3,1,msg3); I2C_LCD_Out(Waddr2,4,1,msg5); delay_ms(5000); I2C_LCD_Cmd(Waddr1, _LCD_CLEAR); I2C_LCD_Out(Waddr1,1,1,(char*)msg6); I2C_LCD_Out(Waddr1,2,1,(char*)"Direct Text Passing"); CustomChar(Waddr1,3,10); I2C_LCD_Cmd(Waddr2, _LCD_CLEAR); I2C_LCD_Out(Waddr2,1,1,(char*)msg6); I2C_LCD_Out(Waddr2,2,1,(char*)"Direct Text Passing"); CustomChar(Waddr2,3,10); while(TRUE){ //TODO: User Code } }
