Multiple Grounds issues in Cadence LVS
Ali263
Member level 1
Member level 1
Hi ,
I am designing a circuit in 65nm cmos process which has different VSS connections for analog and digital part(VSS! and AVSS).
However whatever i do, i get the below 50, 50 errors as shown in picture attached.
Can someone understand from the attachment what exactly it means?
What is the meaning of two **VSS! or **AVSS?
It's clear what it means - you have one net, AVSS, in the schematic (source), but two nets in the layout - AVSS and VSS!
Somehow, the bulk of the MOSFETs gets connected to VSS! - that why there is instance (pin) mismatch between schematic and layout.
I do not know how to resolve this, but this should be a pretty standard situation, and the resolution should be easy and well known.
You can try declaring AVSS net as a ground - the instance mismatches should go away (but net mismatch will still be there).
Many PDKs have inherited connections that default to a "safe" global net like vss! If the net property is not set explicitly or by wire with the B terminal exposed. Check properties for stale VDD! references.
