Multiple clock domain sync
vintujose
Hi I am a new bee
I need to how is the sync between two clock domains is done .
How can i design it using VHDL without using the Async FIFO .
if anybody has a generic code please pass on to me
with regards
kewl
PLease use search in this forum, that topic had been addressed few times
Maybe you already got the answer, but anyway :
To sync a signal coming from another clock domain you can use a double FF synchronizer, for example :
process(clk, rst)
begin
  if rst = '0' then
    in_sig = '0';
  elsif rising_edge(clk) then
    tmp <= in_sig;
    in_sig_s <= tmp;
  end if;
end process;
where in_sig is the input signal to be synchronized and in_sig_s is the signal synchronized to clock domain clk
hope it helps !
yours,
Said
    vintujose
Hi shnain, your solution is ok, but my case is a bit different,can you solve it?....Like my design(FPGA) communicates with a CODEC which has a clk of 2MHz,but however the codec is a master here...You can't make any handshaking to that.Because it's clk is not controllable.....Is there any solution to sync this clk?....and sample the data with my synchronized FPGA clk?...
Clock domain synchronization is not a simple solution, because of the metastability problems. This problem is quite large and you should investigate a little on Internet to understand what it is. However, there is two solutions :
1 - for a single signal use 2 cascaded flip-flops, synchronized with the destination clock.
2 - for a dataflow, use a FIFO with two clock domains (the FIFO integrates the necessary logic to manage properly the clock domain crossing problems).
Good luck
Do you mean, implementing Asynchronous FIFO?....
