archusvijay1
Member level 3
![Member level 3](/styles/images/ranks/dlevel3.gif)
i tried to implement a multilevel inverter. i done already in matlab which shows what i want. during the hardware implementation the output voltage shows the same result as in matlab if load is zero. when i connect a load the output voltage becomes zero no current flows through it.why this problem occurs.
the sources are 3 nos of 12V battery which are in good condition.
