Gaber Mohamed Boraey
Full Member level 4
Hello
Please see this photo as I've just purchase this tester and I don't think it's like my expectations before I buy
Anyway, I bought and need your opinion about it
It came without manual, so I don't know the range at which this device work, as I've noticed that it work fine with some components and not with others
As you see at the pboto6, I test IGBT and it only read doide, I test Thyristor and it only read resistor
While I measure mosfet 20N60, it read right
How you think?, is it a bad component which give fault readings?, or the device can not recognize?
As that IGBT I just purchase from local supplier and I already installed in the machine and it does its job, so why device give wrong read?
